VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Paint question
Old Sep 15, 2009 | 12:53 PM
kpb46's Avatar
kpb46
Default Paint question
I want to paint my brushed aluminum Vrod. Are there any special steps that need to be done because it is aluminum? Are the painted models aluminum also?
Thanks in advance
Old Sep 15, 2009 | 01:31 PM
joechief's Avatar
joechief
Thanks in advance
No, it's a pretty simple process. I am an old painter and now work for an automotive paint distributor. The simpliest way to paint your V-Rod is to throughly sand the aluminum with 320 grit sandpaper. Blow it off, wipe it with a good wax and grease remover then prime it with an epoxy primer. With many epoxy primers, you can paint directly over them, in other words, you would use the primer as a primer sealer. The one thing to remeber about aluminum is that it is a self-healing metal, it starts to oxidize very quickly. So you want to prime it immediately after sanding. If you have any filler work that needs to be done, you can apply it to the roughed up bare aluminum (80 grit), or it can be applied over the cured epoxy primer. If you want to primer surface the bike and block it to get it really straight, the primer surfacer can also be applied over the epoxy. More than likely the tin on your bike is undamaged so you could just epoxy prime and go right to the topcoat or base coat/clear coat. Consult with your paint distributor, we sell PPG which is a good brand, but all paint brands have good systems as well. Hope this helps!
Joechief
Old Sep 16, 2009 | 11:48 AM
Herr Monk's Avatar
Herr Monk
Why don't you just buy a set of colored tins. Prob wouldn't cost that much different... Seems a shame to loose the originals.
Old Sep 23, 2009 | 08:44 AM
bdsbigzrx's Avatar
bdsbigzrx
Default here's one
check this one out: http://www.bdscycles.com/harley_davidson_vrod.htm
Drea
Powdercoat & Paint
May 24, 2015 10:01 AM
STN
Powdercoat & Paint
Jan 11, 2015 09:14 PM
Ace07FXDL
Powdercoat & Paint
Jul 3, 2012 04:27 AM
cuda67bnl
Oct 29, 2009 02:27 AM
harley1969
Feb 26, 2008 09:38 AM
