VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Just purchased 2005 V Rod
Old Jan 16, 2007 | 04:49 AM
rogersachs's Avatar
rogersachs
Default Just purchased 2005 V Rod
Just joined. See my poste under " General"
Would appreciate any advise or tips.
Roger rogersachs@comcast.net
Old Jan 16, 2007 | 03:08 PM
eazy's Avatar
eazy
Default RE: Just purchased 2005 V Rod
Welcome to the forum. Congratulations on your '05.
What type of advise or tips are you looking for?
Old Jan 17, 2007 | 01:02 AM
eazy's Avatar
eazy
I see what you were getting at:
ORIGINAL: rogersachs
Does the 2005 have a 3 or 5 gallon tank?
As stated: 3.7 gallons, but I've never been able to get more than 3.4 when totally out of gas. Harley-Davidson switched to the 5 gallon tank in the VRSCs in 2007.Hate to brag, and I'll start a thread when I'm released from my confidentiality agreement, but I have a 5 gallon tankin my '06
With 7500 miles should I change tires?
If they are worn out, yes. If not, there is no need unless you want to go to the 200mm. I changed mine a 7200, but that was strictly because they were so worn they were becomingunsafe to ride on farther.
Should I have a bib for the top of the tank?
I have one for mine, but some say that it allows dirt to get beneath and scratch the paint. If you put one on, take it off carefully every time you wash the bike. Before you put it back on, make sure the underside is clean.
What size windshield so wind just goes over my head?
It depends on your height. I have a Memphis Fats 21" and look over it by about an inch, give or take. I use it for long trips, but I also use a 13" for shortertrips and none for around town/short runs.
Old May 23, 2007 | 02:25 AM
bludevlbutterfly's Avatar
bludevlbutterfly
I also just bout a v-rod 05 and was woundering if these had any common problems?
Old Jun 9, 2007 | 01:21 AM
bluehwytn's Avatar
bluehwytn
Heres another site to check out. www.1130cc.com. It used to be the v-rod forums but the moco was a bit upset so they changed the site name. Lots of great stuff.
Old Jun 9, 2007 | 08:56 AM
eazy's Avatar
eazy
ORIGINAL: bluehwytn
Yeah, if you tote the line and fall in like sheep. Don't ever have an opinion of your own, it's highly frowned upon.
rlac
Jul 27, 2017 05:23 PM
vrod87
Sep 17, 2014 06:29 AM
rogersachs
Jan 16, 2007 03:25 PM
O5HOG
Jan 25, 2006 01:21 AM
