clutch
My clutch is adjusted so that is most of the clutch lever movement is feathering and the clutch fully engaged when the lever is let all the way out. I didn't set it up but I like it. Slipper clutches feel like they slip because there are a number of friction discs that each grab the next in sequence. Sure you don't have a properly functioning clutch and just think it is slipping?
Hard to get a wheel chirp on a down-shift out of a VRod because of the slipper but also because of the belt drive -- which takes up some of the shock load.
I would suppose there is a way to test the clutch to see if it is correct but I would accelerate maximum through all the gears from 1st on up and try to "feel" for slip. Also in 1st... rolling along at a smooth idle and then throttling hard your front end should literally lift off... I could just feel differently than what you are used to. My brother rides a Honda Shadow and when he rode my VRod a couple things he noticed right off was: 1) When it shifts -- you feel it -- there is no doubt about it; 2) Shifts are smooth.. no wheel chirp... almost like the clutch is slipping -- but it isn't.
Got something installed wrong is my guess. Did you disassemble the clutch assembly before installing? Why did you rebuild the master and slave something may be wrong there?
I have had mine not disengage if i dont purge the DOT 5 fluid. Let it ago for 2 years and had to purge it. This year going to go to DOT 4 suppose to last longer without absorbing moisture like DOT 5.
Dennis
Dennis
Hi Dennis, I think you have your brake fluid backwards. DOT 5 (not 5.1) is silicon based and does not absorb moisture. DOT 4 which is the same as DOT 3 (both are glycol ether based)but has a higher boiling point, and absorbs moisture.
did you get your clutch issue resolved? Curious what you found?
Hal
Yes probably have my facts wrong. After a couple years if I don't purge the DOT 5 my clutch will not fully disengage and gets real grabby. It usually happens after sitting thru the winter when I don't ride it. I have a home made pressure setup that purges all the old DOT 5 and everything is fine.
I was reading articles about it and they said just purge the DOT 5 with DOT 4 and the problem with DOT 5 goes away. Steve said that was the way to go. Haven't tried it yet but will probably do it in the spring. Thanks for correcting me if my statement was wrong. I don't want to give out incorrect info to anyone.
Hope your doing ok and will hopefully see you in March when the new Granddaughter arrives!!!
Dennis
If the springs are loose then it looks like there is something not assembled correctly. The four bolts that hold the springs in place also put tension on the plates to keep the plates engaged. When you originally installed it it should have already been bolted together and just slipped into the clutch basket. You may have had to loosen the 4 bolts to remove spring tension to allow alignment of the plates and the shaft splines but that's it.
I know that if the clutch basket falls off the inner hub it has an alignment key and you have to us a small drill bit to relocate and then hold it into position. I think it is addressed in the maintenance manual. I didn't check sorry.
I have attached an exploded view of the slipper clutch. Hope this helps.
Dennis
