Harley top engine noise.
Old Nov 24, 2023 | 07:37 PM
Rounders's Avatar
Rounders
Originally Posted by Jackie Paper
It is mostly people here telling you where they are from, and acting like it is the first day you owned a harley.
It wouldn't so bad, if it wasn't for the members.
Old Nov 24, 2023 | 09:57 PM
Glenn Gorman's Avatar
Glenn Gorman
Originally Posted by Rusty Springs
I don't have a problem with it. Good luck though. I hope you make a lawyer a lot of money and get your $5.17.
While the lawyers make millions.
Old Nov 25, 2023 | 10:17 PM
Faces103”'s Avatar
Faces103”
Stage II
Default Thank you.
Originally Posted by Spartanden
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
I did that with my truck. Mostly I’ve just got a big box full of all the stuff I’ve removed or swapped. I’ve decided to keep it, have a guy crack it open and bulletproof it. Add a little torque but mostly address the common problems ahead of time. Maybe even do the crank to prevent runout. Too much added already to start over so all in.
Old Nov 26, 2023 | 08:03 AM
Rounders's Avatar
Rounders
The guy just copies and pastes that into every intro assuming people bought their harley 10 minutes ago. He is from below the bridge.
Issysportster
Sportster S
Jan 10, 2023 11:21 AM
martin10
Oct 13, 2017 05:21 PM
russrudder
Jul 2, 2017 11:05 PM
russrudder
Screamin Eagle CVO Models
Sep 5, 2012 05:23 PM
missboy
May 15, 2011 10:25 AM
