check engine light on after changing oil
Old May 19, 2008 | 09:38 PM
2000lowrider's Avatar
2000lowrider
Stage IV
Default check engine light on after changing oil
I have changed the oil ion my bike for eight years and cleaned it up changed the oil this time cleaned it up with cleaner and got every thing wet with brake cleaner cleaned all connections out but now check engine comes on about 5-8 seconds after you start it up has code 42 cam sensor bike runs fine harley shop it created a ghost code and needed to be cleared so does anyone know how to do that cycling the key dosent do it and its getting annoying now Thanks:[:@]
Old May 19, 2008 | 09:48 PM
Motown Glide's Avatar
Motown Glide
Default RE: check engine light on after changing oil
Try going to your model and post for help! Welcome from Motown!
Old May 20, 2008 | 12:11 AM
RKKY's Avatar
RKKY
Don't know what year bike you have, but this works on most: Pull up the code and then hold the odometer reset button in until is says "cleared". Unless it's triggered again, your engine light should stay off.
Old May 20, 2008 | 06:59 PM
Airywhisler's Avatar
Airywhisler
Hummmmmmmmmmmmm
Old May 20, 2008 | 09:49 PM
skltr's Avatar
skltr
[sm=welcomesign.gif]
Old May 20, 2008 | 10:43 PM
2000lowrider
Stage IV
2000 FXDL LOWRIDER
Old May 21, 2008 | 09:26 AM
rjmac53's Avatar
rjmac53
Welcome to the forums !!!
Old May 22, 2008 | 12:09 PM
wdg's Avatar
wdg
welcome from maine
Old May 27, 2008 | 10:28 AM
XRP's Avatar
XRP
Welcome from Cold Lake, Alberta.
Old Jun 3, 2008 | 09:56 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
HI
