Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
i have a 1992 heritage softail. i recently replace the detent spring in the transmission. it had snap off and shifter would not return to central position. anyway. i now have a vibration that i cannot figure out. i removed and installed the compensator with an impact and am wondering if that didnt mess something up. this is all new to me so i have several questions. i surely could not have messed up timing because from what i understand the bike has ignition timing and cam timing and i did not mess with either one of those in the process of changing the spring. i am thinking that it is in the compensator, chain or chain tensioner which i have adjusted many times to no avail. any help would be greatly appreciated
This is the new member greeting area. There are a lot of member that never come here.
The forum has many areas/sections... this question would get a lot more looks and answers in either the softtail section or Engine section in the TECH area.
U can get there from the main page.
Also use the Search feature at the top of the page, there has been many question about the comp in the past and U can look up for some answers...
Take a little time and look around in here, there are so many areas to read, learn and ask question in.
Glad to have you join in the fun. Great place to hang around.... you may learn a little, may learn a lot, may not learn anything. But you will have a few good laughs and make some new friends. Welcome. Geez
