Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
I replaced my cams installed andrews e-z adjust push rods.
I turned the motor over before the front cyl lifters bled down.i tried to start is (STUPID) at first it back fired I shut it right down. re adjusted the push rods
then did a compression check, at first no compression in the front cyl.
I waited 15 minutes and checked compression again. this time had full compression. I buttoned it up and now it starts and runs fine.
i don't think i bent a valve because it runs good. Can anyone out there tell my why i did not have compression the first time? I made sure i started it many times. Can't ride it yet due to the snow.
Did i get lucky and the intake lifter was just holding the intake open at first?
No i did not adjust the valves, i figured I would let the lifter bleed down.
the only reason i am asking is I just find it strange that it did not have compression the first time????????????????
