electrical fault
Old Jan 24, 2010 | 05:55 PM
ilbeback's Avatar
ilbeback
3rd Gear
Default electrical fault
Help! got an 06 dyna with an annoying electrical fault.
it cuts out for a split second, especailly under load. then it seems to go away. i know its electrical as the speedo needle drops when it cuts out....
Old Jan 24, 2010 | 06:23 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Welcome from So-Cal. Try the Dyna section for more specific answers.
Old Jan 24, 2010 | 07:03 PM
HotRoc54's Avatar
HotRoc54
hello from pa. check out the dyda thread.
Old Jan 24, 2010 | 08:24 PM
tjvrodrick's Avatar
tjvrodrick
Welcome to the forum. Have fun Here, Ride Safe
Old Jan 24, 2010 | 09:33 PM
oct1949's Avatar
oct1949
The first thing to check is the battery cables. makes sure the bolts/cable ends, to it are clean and tight.. theres been a lot of cutting out issued this past summer, including mine..and this fixed it...
Next I'd try some brand of dry gas to get rid of if any moisture in the tank..
Also might try unhooking the ECU for a second and reconneting it back..
These are three easy ones.. after that could be fuel filter or the line to filter in the tank having a small hole in it.
If none of above then wiring/fuses, needs checked.....Well at least as far as I know...
Welcome aboard HDF
From Indiana.
Old Jan 24, 2010 | 10:20 PM
hpfatboy's Avatar
hpfatboy
Thumbs up
Welcome from Vancouver B.C. CANADA
Old Jan 24, 2010 | 10:48 PM
chance's Avatar
chance
Hello and welcome to HDF from NorCal...
Old Jan 24, 2010 | 11:38 PM
Big Rol's Avatar
Big Rol
Welcome to the forums from Cape Breton Island, Have Fun & Ride Safe
Old Jan 25, 2010 | 03:29 AM
ilbeback's Avatar
ilbeback
3rd Gear
Welcome aboard HDF
From Indiana.
really grateful for your help and advice....many thx
Old Jan 25, 2010 | 03:35 AM
ilbeback's Avatar
ilbeback
3rd Gear
thanks for your help and advice.....guess ill be busy for a couple of hours now.
thanks again
gary
