manifold pressure sensor (MAP)
Old Aug 22, 2006 | 06:44 AM
Kraza's Avatar
Kraza
1st Gear
Default manifold pressure sensor (MAP)
Hi Guys I've just joined from down under Australia so just bare with me. The (MAP) system on the 88 twin cam can I get rid of it some how all info would be greatly appreciated . Looks like crap customizing the bike [:'(]
Old Aug 22, 2006 | 07:23 AM
millzog's Avatar
millzog
Big Kahuna HDF Member
Default RE: manifold pressure sensor (MAP)
Kraza, welcome to the HDF, I would post your question in one of the tech forums. The people there can help you better ! Good luck and ride safe !
Old Aug 22, 2006 | 09:05 AM
atrox88's Avatar
atrox88
ORIGINAL: millzog
What he said and welcome from Union Bridge, Maryland!
Old Aug 22, 2006 | 10:08 AM
grunt's Avatar
grunt
Howdy From Dallas. Definitely check the tech sections and the model-line specific areas too. But most likely not w/o some other change. Those are used to calculate the A/F mixes under differing loads, so unless replaced w/some other mix-controller ECM, you could run rich or lean at different times in a ride.
Old Aug 22, 2006 | 10:30 AM
wuudbee's Avatar
wuudbee
Welcome to the Forum from LOUISIANA
Old Aug 22, 2006 | 11:02 AM
100thRK's Avatar
100thRK
Check out the tech forums.
[sm=biker2.gif] [sm=biker.gif] [sm=biker2.gif] [sm=biker.gif][sm=biker2.gif] [sm=biker.gif]
Welcome to the Forums from Louisiana!!!!!!!
[sm=massbounce.gif] [sm=groupwave.gif]
Old Aug 22, 2006 | 12:13 PM
cjmilez's Avatar
cjmilez
Welcome to HDF from Longview,TX!!!!
[sm=biker2.gif]
Old Aug 22, 2006 | 12:55 PM
rj164's Avatar
rj164
Hi from So Calif
Old Aug 22, 2006 | 02:12 PM
Blackbird's Avatar
Blackbird
[sm=usa.gif]
Welcome aboard from Omaha, NE.[sm=biker.gif]
Old Aug 22, 2006 | 02:53 PM
fatboymike's Avatar
fatboymike
Welcome to the forums, from New Jersey
