wildpig1 1995 flstn
Old Apr 7, 2016 | 01:48 PM
wildpig1's Avatar
wildpig1
4th Gear
Default wildpig1 1995 flstn
When replacing the front wheel, what is the correct procedure to get proper spacing between the axle spacer and the fork lower on the right side?
Old Apr 8, 2016 | 06:36 AM
multihdrdr's Avatar
multihdrdr
1995 FLSTN - Tapered wheel bearings..."Timkens"
All the important stuff is happening on the LEFT side. The Right side spacer is really only doing two things, none of which is spacing the slider (or lower). It provides a sealing surface for the grease seal and "positions" the axle. The spacing between the spacer and slider really "is what it is"...insignificant
Also for clarification, The right-side large end of the axle "doubles" as a portion of spacing (spacer)
Ken D
Nov 30, 2017 09:24 PM
jimijet
Sep 13, 2008 06:59 PM
