Tiny lil hole problem
Old Aug 20, 2016 | 10:45 PM
EndOfAnEra's Avatar
EndOfAnEra
Default Tiny lil hole problem
I picked up something the other day and lost pressure in my front tire. It's a spoked with a tube. I did the soap test and couldn't see any bubbles, couldn't see anything either. Pumped it up overnight and it was pretty flat again.
Dealership took it and found a tiny pin hole that punctured the tube, but nothing in the hole. The tech at the dealership is saying they usually always reccomend a new tire, but the hole is so tiny he's asking if I'd rather leave the tire and replace the tube.
I've seen some talk of this with tires with no tube, but I'm not sure what to do on this. Tire is new this season. If the hole is really that small, do I have anything to worry about?
Old Aug 20, 2016 | 10:53 PM
QC's Avatar
QC
Nope, throw a patch on it and tube in it and ride on.
Old Aug 20, 2016 | 10:58 PM
EndOfAnEra's Avatar
EndOfAnEra
Thanks. Con artists at HD trying to sell me a stock Dunlop for $260.
Any suggestions for a patch? Never done a motorcycle tire before.
Old Aug 20, 2016 | 11:01 PM
QC's Avatar
QC
Not really. Even a Skab from Slime would work in this situation. Just want to cover the hole so a new tub doesn't get pinched.
Old Aug 21, 2016 | 09:03 AM
im's Avatar
im
Dealers will almost always want to replace with new.
Some folks go with a patch while others go with a new tube.
If wheel is coming off then i would remove the tire, inspect internally and then replace tube.
If i was on the side of the road, i would use some ride-on tire sealant.
If i had time i would take it to an independent and would avoid the dealer.
daveMD2011
Aug 3, 2011 04:53 PM
CALNNC
Wheels/Tires
Mar 22, 2011 10:39 PM
June Bug
May 28, 2009 09:46 AM
firestop52
Aug 2, 2008 07:04 PM
richp5
Oct 11, 2007 01:56 PM
