Harley wheel interchangeability
Old Sep 19, 2016 | 04:35 PM
MC1attack's Avatar
MC1attack
Stage I
Default Harley wheel interchangeability
Will a 2000 Road King spoke wheel fit a 2003 Heritage Softail?
Old Sep 20, 2016 | 04:26 PM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. Yes, the wire-wheel hub is the same on both RK and Heritage models. You can check stuff like this using an on-line parts website.
Old Sep 20, 2016 | 09:27 PM
multihdrdr's Avatar
multihdrdr
Rear or Front?
Rear
The hub is the same, but the laced offset isn't. HD changed the Softail offset in 2003. If you install that RK rear wheel on that 2003 Heritage be aware that the wheel will sit slightly more to the Left (clutch lever side) than the original wheel.
Front
The RK wheel and the Heritage wheel have a different dimensions from bearing edge to rotor mounting surface
megawatt
EVO
Jun 12, 2019 08:32 AM
PRrdglide
Mar 30, 2018 10:55 PM
tsobash
Aug 3, 2017 12:04 AM
Compo48
Wheels/Tires
Mar 3, 2010 10:17 AM
HARLEYMAN69
Jun 1, 2008 07:49 PM
