Tires getting hot
Old Dec 13, 2016 | 04:17 PM
jimihd's Avatar
jimihd
Default Tires getting hot
Does anyone know why Dunlop tires seem to run hot? On several bikes I have ridden over the years, my Dunlop tires get HOT to the touch after about 20 miles. I have proper inflation and have actually tried over inflation and see no real reduction in temperature.
Old Dec 13, 2016 | 04:34 PM
shorelasHD's Avatar
shorelasHD
Hot tires will give better traction-in fact, racers use electric "tire warmers" to keep their tires warm between races on track days, maximizing traction and improving tire life by reducing the number of heating/cooling cycles.
Of course, stock Dunlops are a far cry from racing slicks or super-/ hypersports, but I'm curious if anyone on the Forum has some temp numbers...
Old Dec 14, 2016 | 02:10 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Science 101. Friction creates heat. The more heat that's generated by a tire the better the road holding capabilities of the tire.
Old Dec 14, 2016 | 10:24 AM
grbrown's Avatar
grbrown
You don't mention what other bikes you have ridden. Harley tyres are intended to give very high mileage and don't compare with the tyres of most other brands of bike. Harleys are also heavier than many other bikes, so put their tyres to extra work. If you are very heavy, routinely ride 2-up or otherwise heavily loaded, then by all means increase tyre pressures accordingly. Otherwise I would be surprised if there is anything actually wrong with them.
Old Dec 14, 2016 | 08:23 PM
jimihd's Avatar
jimihd
The other bikes are '75 FLH and '97 Goldwing. Both are equally heavy machines. The tires get equally hot. I first noticed it when I stopped and the tires were damp. There was a vapor coming off the tires. Seemed pretty hot to me. Guess it's normal. Thanks!
Kenbow56
Aug 29, 2013 07:37 PM
Bagger Jim
Mar 12, 2012 08:19 PM
strtarrow
Oct 5, 2011 12:58 PM
Mississippi Bagger
Feb 8, 2008 08:35 PM
High Gear
Feb 1, 2007 03:44 PM
