I don't know if your interested, but you can go to Walmart and buy a $7 foot pump with the clamp on 90 degree hose. Cut off the hose and throw out the pump. Install a tire valve, shrader valve, strip off the rubber and clamp it to hose end, then use it for tire fill.
Another option is to buy a 12V pump with the 90 degree clamp on fill hose and gauge and use it, about $25. I have use the Slime brand for a couple years, gauge is accurate.
I have this one from autozone , the lock on works but the gauge was never accurate. http://www.autozone.com/air-tools-an...uge/977879_0_0 Searching for this I see a bunch from Walmart , Lowes, and home depot starting at $6.41. I have a few bikes, between spokes, discs, and drum brakes, there isn't one air chuck that works on them all.
I tried that exact set up on my 2011 RK with the stock wheels and straight valve stems. It's a "3 handed" process and returned it. Gauge read different by 1-2 lbs on each reckeck.
Did this... works great!
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
