2001 wide glide tires
Old Jul 31, 2017 | 10:19 AM
Holtdcw's Avatar
Holtdcw
2nd Gear
Default 2001 wide glide tires
Can a 2001 harley Dyna wide glide take a wider back tire than the stock 130/90/16(Mt 90/16), without any modifications? Like not a ton wider like would a 140/85/16 fit with no mods? Could you go even wider? Any feedback is appreciated!
Old Aug 1, 2017 | 09:05 AM
grbrown's Avatar
grbrown
Wink
Both a 140/85 and 150/80 will fit the stock wheel (I've done that on other models), which leaves us with clearance with the beltguard. You may find a 140/85 will fit, although it may be darned close or require mods to the belt guard - I removed the rubber inner part on my older bike. If you have the 1 1/2" wide belt I'm going to guess a 150/80 won't quite fit. Pop into the Dyna section, where they should be able to give you a better answer.
Old Aug 16, 2017 | 04:40 AM
Holtdcw's Avatar
Holtdcw
2nd Gear
Not talking about the rim I Know it will fit the rim I'm trying to get something wider under the fender with belt clearance and no mods
Old Aug 16, 2017 | 06:13 AM
zahra1234's Avatar
zahra1234
Stage II
niceeeeeee
McMurphy
EVO
Aug 1, 2013 06:03 PM
sherlock342
Wheels/Tires
Jul 27, 2013 08:38 AM
Wide Glide Ride
Oct 3, 2010 02:38 PM
LozoB
Wheels/Tires
Aug 31, 2010 09:53 PM
El Chiguete
Aug 3, 2009 12:36 PM
