Calling tire gurus
Old Nov 23, 2017 | 05:21 PM
xpsteve's Avatar
xpsteve
Default Calling tire gurus
looking to replace the the Dunlop 180/55ZR18 on my 2013 Ultra Limited. It is a 107 stage 4 and I do exercise the extra ponies on a regular basis. The last tire seemed to only last about 4k miles and I was easier on it than the tire before. I don't seem to have a lot of options on this tire due to size. Kinda have ruled out the Metzler 888. looking at the Night Dragon and the Commander II. I also see tires offered in radial and bias ply. I do like cornering hard and from what i read, the bias might fit my needs better. Can someone in the know enlighten me? I'm looking to get more miles per $$$$ too.
Old Nov 25, 2017 | 05:26 AM
grbrown's Avatar
grbrown
Cool
With that size of tyre you are going to find a limited range of options IMHO. As for tyre types, for decades they were mostly cross-ply, until the bias-ply type became more popular. Radials were originally only suitable for cars not bikes, but technology design and materials have all moved on. I use radials on front and rear of my Buell and Sportster, bias front and radial rear on my Glide. It is conventional when mixing both types to use bias front with radial rear, not the other way around.
Looking at tyres of your size, the radial versions seem to have a low load rating, whereas the bias type have a much more suitable load rating. In the case of the Avon Cobra, the bias version has a LR of 80 and is reinforced, so in your circumstances that would be my choice. Their radial tyre only has a LR of 74 and is also Z speed rated, so will have less tread and have softer rubber, so is unlikely IMHO to last very long!
Hope that helps!
Old Nov 25, 2017 | 08:43 PM
bigskyroadglide's Avatar
bigskyroadglide
I with Mr Brown. Load rating for the 18 is the issue. Dunlop, AE, commander II or Pirelli.
my 12 CVO with a 120R is riding stock Dunlop and is averaging approx 10k per rear. I'm putting an AE on next to see if I can get above 10.
I have pirelli on my 10 fltrx the 16 for the rear has a great load rating and is sticker than the Dunlop. I expect to get 10 or better.
if all else fails, you could consider the dark side.....
Old Nov 30, 2017 | 01:23 AM
bklynbob's Avatar
bklynbob
Going by the second sentence in your post,no tire will give you the mileage you want. Irun the Avon Cobra and highly recommend them.
Old Nov 30, 2017 | 06:31 AM
Notgrownup's Avatar
Notgrownup
Dark side seems to be the way you should go if you like to exercise the ponies...Any MC tire won’t last, specially the softer compound ones...You wanna play, you gotta pay.
Old Nov 30, 2017 | 08:04 AM
eaglefan1's Avatar
eaglefan1
Ive had the Avon Cobras on for 2 weeks, they are outstanding tires. How long they last wasn't a big concern for me. Safety in wet and dry was the most important factor in my choice
DeplorableOne
Jul 13, 2019 12:00 PM
AGAF
Sep 25, 2016 11:54 AM
Iamdent1
Apr 3, 2013 11:09 PM
trappermarc
May 16, 2012 10:21 PM
CLL375
Mar 17, 2011 07:37 PM
