Rear tyre is rubbing my turn signal wire ?
Received 4,614 Likes
I had one eaten through by the tire, spliced it and since there was too much stretch between hold points, tire could still reach it, I just cleaned off the fender real good there and secured the wire to it with red RTV sealant - that stuff is really durable. If there isn't enough slack in the wire to reach the fender, splice in another inch or two. Should have a little metal tube welded to the fender for the wire to run through, that's really vulnerable just hanging in there. I've heard of several Harleys eating turn signal wires.
What changed is that he put a 180 on a bike that originally came with a 160.
Harley made a "180 MM WIDE TIRE KIT" (including a Tire) which included some hardware and instructions to address clearance issues.
I think you can still get those brackets separately. Although you may be able solve this with what you have, you'll have work on that
Here's the Instructions:
grbrown (07-16-2018)
JimInMich
06-18-2012 06:20 PM
