Tyre pressure for FXDWG
Old Jul 29, 2018 | 05:05 AM
Ivor's Avatar
Ivor
Stage II
Default Tyre pressure for FXDWG
Can you tell me what the correct pressures for the tyres on my FXDWG, the bike is year 2000, and I have changed front and rear recently, I bought Dunlops, tthe service book states 30psi front and 36psi rear for solo riding, but the garage that fitted these new tyres say that because the tyre technology is now much different to 18 years ago I should put 40psi in both front and rear. Is this correct
Old Jul 29, 2018 | 05:14 AM
Hoginedgewood's Avatar
Hoginedgewood
Welcome to the forum, the respectful thing for new members is do an introduction in the proper section before asking for assistance.
i had the same question for my 1984, I ended up using recommended tire pressure for modern similar bikes with same tires as what I was buying. I don’t like when tire stores just go by max rated tire pressure, I believe it should go by the weight of the vehicle on the tire.
What are your new tires rated for max psi?
Old Aug 3, 2018 | 08:20 AM
grbrown's Avatar
grbrown
Cool
Ivor, hello old chap from North of the Thames and welcome to HDF. To be blunt I would ignore your fitter! I've been riding since the 1960s, owned Harleys for over 40 years and have always used the owners manual as the basis for setting tyre pressures. Tyres are indeed very different today, for the better, but I'm not aware that pressures are any different. Refer to Dunlop's own website, where you should find their recommendation. If you are heavy or light, consider making small pressure adjustments up or down, to optimise ride comfort.
Old Aug 3, 2018 | 11:06 AM
Ivor's Avatar
Ivor
Stage II
Ivor
Thanks grbrown, nice to hear from someone this side of the pond, after reading your reply I phoned my dealer, he diagrees, says tyre presures are governed by weight and style (to some degree) of bike model, but pressures must complement the suspension, he also said that running tyres at lower pressures can affect steering (particularly on bikes like FXDWG) and can lead to dwelling at corners / roundabouts aswell as excessive wear. It appears there are many opinions, I think I'll try 36 front 40 rear and see how it feels. Many thanksfor your imput.
Old Aug 3, 2018 | 11:52 AM
grbrown's Avatar
grbrown
There are some mixed messages in those words! As I suggested, check the Dunlop website - you may have to search for the Dunlop USA site, to get Harley pressures. Any figures they supply will be for your older bike with their newer tyres.
As an aside, I visited a suspension specialist at Silverstone last week, to have my 2007 Buell suspension checked and adjusted. He actually recommended reducing my tyre pressures by 2psi per wheel from the recommended levels, which is the opposite of your dealer's suggestion. One of the bikes I saw being race-prepped is a Tyco BMW BSB racer.
az232
Sep 3, 2018 12:37 PM
wyotana
May 24, 2014 11:38 PM
Topspin
Aug 17, 2010 04:22 PM
JMSporty
Mar 13, 2010 12:22 PM
fatboy57
11
Mar 23, 2007 01:58 PM
