i did did some research but wanted some further info from you all. I have a 13 street glide and I will be trying out the Bridgestone battle cruise h50’s front and rear. (Will update when miles are logged) do you run the oem pressure, look at the after market tire pressure and calculate from there, chalk trick to find the proper pressure?? I was hoping for some advice.
Stock bike
some two-up
mostly solo rides around backroads
occasional long trips
It appears as though the design for the Bridgestone Battle Cruise H50 and the Bridgestone Exedra Max are the same tire or at least the same tread design.
As for tire pressure, run the same as you would the OEM tires. Check either the service manual if you have one, or the owners manual.
