Front Wheel Road King Classic
Old Jun 9, 2019 | 03:16 PM
Standerfer66's Avatar
Standerfer66
Stage III
Default Front Wheel Road King Classic
Newbie here, I have an 11 Road King Classic with a bent front wheel, is the wheel from an 06 the same size? Is it a direct replacement?
Old Jun 10, 2019 | 07:43 PM
multihdrdr's Avatar
multihdrdr
Same size Front Wheel ... 16 x 3"
But you'll need to change the bearings in the 06 wheel to your 2011 25mm Bearings and Center Spacer Sleeve ... You'll also need a Bearing Shim
You can get it all in the HD Wheel Installation Kit OR purchase the Shim and Center Spacer Sleeve separately and get the bearings elsewhere
If you need part #'s, let me know
Old Jun 11, 2019 | 08:43 AM
Standerfer66
Stage III
Thank you so much for the info, do you mind giving me the part #'s?
Old Jun 11, 2019 | 07:05 PM
multihdrdr's Avatar
multihdrdr
Do you have ABS? ... BELOW is for NON ABS equipped Bikes
41455-08C ($79.95 list) is the Front Wheel Installation Kit ... includes (2) 25mm bearings, Center Spacer Sleeves, Bearing Shims and more ...
** USE THE CORRECT PARTS FROM KIT
OR
You can get ...
(2) 6205-2rs 25mm bearings (everyone who sells bearings has an equivalent to that bearing #)
(1) 43903-08 ($22.32 list) Bearing Shim
(1) 41900-08 ($10.47 list) Center Spacer Sleeve (OR re-use the one from your 2011 wheel)
The Bearing Shim goes under the Left Front Bearing (inserted before installing the bearing)
This will give you the concept ...
Sealed Wheel Bearing Shims/Spacers - What they look like...Where they go
Old Jun 14, 2019 | 08:10 PM
Standerfer66
Stage III
I appreciate you taking the time to help me.
shorty07ultra
Oct 14, 2023 03:46 PM
robbie52
2014-2024 Touring Models
Jun 28, 2017 08:01 AM
Electraslide91
Aug 16, 2013 12:42 AM
Wally
Jan 3, 2013 07:02 PM
elwoodto
Mar 17, 2010 06:38 AM
