want to change my STOCK 19in front wheel. 07 Dyna Street Bob, mid-glide,.can get 21in wheel off 05 narrow-glide for good price. Any body done this, WILL IT WORK? Any help and advice appreciated.
Sure you can ... At least you'll need need Different Wheel spacers, some Caliper spacers, and swap your 11.8" Rotor over (Re-using your rotor if you have the Stock SB laced spoke wheel)
Depending on the wheel and where it came from, you might have to change the bearings, center spacer sleeve and Enlarge the "Clearance Hole" for a 1" axle/sleeve
Have a pic of the wheel?
