Help
Old Feb 27, 2020 | 09:22 PM
HDEletrca's Avatar
HDEletrca
Stage III
Default Help
So bought the 19 inch enforcer. I have a 2003 electra glide want to install it on. I’ve been told several different things on parts I need and things I need to change out can someone lead me in the correct direction
Old Feb 27, 2020 | 09:59 PM
EVOrider's Avatar
EVOrider
Your bike has one inch bearings.....
Touring models came with 25mm bearings in 2008-up. Abs models used two different bearings.
You need to know what size bearings are in this Enforcer wheel first. If one inch....simple bolt on.
If 25mm......Bearings change, axle changed or turned down, proper spacers, Brembo rotors/ calipers.....
My opinion.....the one inch bearings are better.
Old Feb 27, 2020 | 10:40 PM
HDEletrca's Avatar
HDEletrca
Stage III
I was told when it came to the calibers I could use the ones I have
Old Feb 28, 2020 | 06:57 AM
EVOrider's Avatar
EVOrider
If....your rotors mount to the new wheel, you can use your calipers.
MadScientist323
Welcome Area Only
Feb 23, 2020 07:49 AM
kazanimo
Sep 19, 2019 04:50 PM
jackavelli
Apr 30, 2014 05:22 PM
bayswhc
Nov 22, 2012 07:02 PM
Txasholdem
Apr 10, 2012 09:43 AM
