Wheel size change
Old Mar 11, 2020 | 05:08 AM
Shaun Baynum's Avatar
Shaun Baynum
Stage II
Default Wheel size change
My 99 Electra glide has been converted to a 21" front wheel. I need a mechanical Speedo drive because mine crapped out. Im pretty sure the ratio on the stock 16" wheel is 2240:60. Is this going to change with the larger wheel. Also I can't seem to find one for a 21 inch wheel anywhere online. I've seen them for an fxr with a 21 inch wheel. Would my best bet be to get one of those and either have it machined down to the correct spacer size?
Old Mar 11, 2020 | 11:47 AM
Zanthamos's Avatar
Zanthamos
Yes it will change with a larger front wheel. The wheel spacers are separate from the speedo drive. The drive units should be the same thickness between the 16" and the 21" wheel.
Roli
Sep 26, 2018 11:50 AM
Bigstakz
Nov 16, 2017 12:22 PM
58Panhead
Dec 19, 2013 08:42 PM
rolfsharley
Dec 3, 2013 01:11 PM
Swamphunter
Feb 5, 2008 07:09 PM
