18" vs 16" rear wheel ?
Old Mar 1, 2021 | 07:27 PM
Clayton24's Avatar
Clayton24
Default 18" vs 16" rear wheel ?
How much of a diffrence am i lookin at on take off power/rpm change with a 1" taller rear tire im going from a 16" rear wheel on a 15 limited to a 18" agressor and all in all its going to be 1" taller tire height . Thanks for an help or info
Old Mar 2, 2021 | 07:02 AM
eighteight's Avatar
eighteight
the difference between a 27" & 28" tire is 32 revolutions per mile or 3.5% difference
just an example as we don`t know what numbers you are working with
Old Mar 2, 2021 | 12:21 PM
Clayton24's Avatar
Clayton24
ok i understand more so the main concern is performance diffrence on take off with 1" taller height tire
Old Mar 2, 2021 | 01:58 PM
eighteight's Avatar
eighteight
Unless the bike is overloaded I expect the difference to be minimal
Using the example above
xx rpm = 60 mph with 16 / 62.1 mph with 18"
XX mph = 3000 rpm 16" / 2895 rpm 18"
Can you source an 18" with lower aspect ratio / height ?
Old Mar 2, 2021 | 07:13 PM
Clayton24's Avatar
Clayton24
Not that im aware of i may just do the tri glide pulley if i feel it decreased the torque on take off noticeably ! Thanks i was on the edge of doin it before the tire swap 😬
springr
May 15, 2014 04:59 PM
Coastiejosh
Sep 23, 2012 07:56 AM
cthecope
Wheels/Tires
Jul 25, 2011 06:41 PM
RFG40901
Screamin Eagle CVO Models
Nov 3, 2010 06:50 PM
Swamphunter
Dec 30, 2007 08:28 PM
