Anyone using nitrogen in their tires?
But, Ive noticed my tire pressure, especially in my rear tire, increases significantly at speed. It would be interesting to take a ride in similar conditions at freeways speed with both ambient air, and purer nitrogen to see the difference.
Unless your bike is parked on a concrete floor, and then the concrete sucks the air right through the tread. That's why you have to park the bike on a scrap of carpet.
If you start out with the "standard" 78% nitrogen blend, as your tire loses pressure, more oxygen seeps out than nitrogen, so now your tire is more than 78% nitrogen.
As days and weeks go by, and you continue to add "air" to your tires, the nitrogen percent continues to rise higher and higher, until you are asymptotically approaching 100% nitrogen.
For free.
You're welcome.
Say it isn't so!
Oh...wait...perhaps you're the one that's incorrect...
"Nitrogen molecules (N2) are larger than oxygen molecules (O2) so therefore, pure nitrogen will permeate the walls of your tires less than oxygen molecules. But by how much?
Well, a nitrogen molecule measures roughly 300 picometers while an oxygen molecule measures 292 picometers. That’s only a 2.6% difference in size. One picometer is equal to one trillionth of a meter (1 m / 1,000,000,000,000)."
Consumer Reports did a study in 2006 where they measured pressure loss of nitrogen-filled Vs air-filled tires over a one year period. They took 31 pairs of all season, automotive tires (H and V speed rated). One tire of each pair was filled to 30 psi with air, the other tire from the pair was filled to 30 psi with nitrogen. All 31 pairs were then set aside, outdoors for 12 months.
Their conclusion was that nitrogen does reduce tire pressure loss over time, but the reduction is only 1.3 psi.
Air-filled tires, originally filled to 30 psi lost 3.5 psi over a one year period.
Nitrogen-filled to the same starting pressure of 30 psi lost 2.2 psi over the same period.
More importantly ALL tires lost pressure, so consumers should check their tire pressures routinely regardless of the gas used.
