I've been looking for opinions for my next tire purchase for while. I'm especially looking for a tire/tread pattern that will best handle tar snakes. I run across a lot of information on how tires perform under wet conditions, with maybe a passing remark on tar snakes, but I haven't found anything that specifically addresses tar strips. Summers in my neck of the desert are generally hot and dry, with very few rainy days, which is why I'm more interested in a tire for these conditions. I know opinions are going to vary, but any feedback would be appreciated. For reference, I've been running stock Dunlops on my 2006 Heritage. I'm leaning toward American Elites, but I'm still looking for more information. Thanks.
Another vote for Metzler. I will say that Vermont uses some type of sealant at the beginning and end of some bridges that is pretty greasy when it's really hot but other than that it's gotta be a real thick and wide tar snake to notice it...and hot.
3rd vote for Metzeler. Replaced my 888's which were fantastic with newest, the Cruisetecs. While I do like the Cruisetecs, I don't love them, I'll be going back to the 888's.
I have successfully run Dunlops and Metzlers, different bikes different tires.
But for tar snakes the solution is simple. Dunlop likes to run the tread groove parallel with the tire therefore parallel with the tar snakes, or metal grating etc. That parallel groove is what gets hung up on the snakes and gives you the wiggle. Metzler seems to prefer a diagonal pattern, they float much better over the grooves.
Seems too simple, but that is what I have found, all about the direction of the tread. If tar snakes are the #1 concern, this is what you need to be mindful of, good luck.
