While I was recently changing the tires on my 2011 Ultra, I was thinking about the instructions in my factory service manual.
Why does the FSM specify to apply a light coat of anti-seize to the inboard side of the cone nut on the rear axle, but makes no mention of applying anti-seize to the nut on the front axle?
Does it have something to do with being able to set/adjust the belt tension?
If I understand you correctly , is that it helps the nut spin more freely against the cam when torquing to spec . I also clean and sand the edge of that nut using fine sandpaper on a flat surface to remove any rough spots and burrs that might be there , do the surface of the cam as well .
Using an axle lock like Jim's axle tool helps a lot , it keeps the cams from spinning while torquing . I also made an alignment tool as well , keeps the bike rolling straight as an arrow .
If the purpose of the ant-seize on the rear axle nut is for torquing to factory specifications, why doesn't the factory have the same requirement on the front axle nut?
My guess , it's because the front axle doesn't move in a Backward / forward motion , just spins , you tighten the the main axle nut , then apply the two nuts to the clamp , done , whereas , the rear needs the anti seize to help prevent the axle from spinning and putting the cams out of placement . Without the axle lock ( Jim's ) , it makes it more difficult to keep the cams in place while tightening the nut to spec . I used to use a large wrench , but it would just move while I was torquing , now with the tool , it stays in place , keeping the belt tension as is .
The anti seize between the nut and the cam on the rear axle reduces the friction between the two parts, so that the cam is less likely to turn while torquing the nut.
