ABS vs Non ABS wheels
Old May 7, 2023 | 02:13 PM
wannavee's Avatar
wannavee
Default ABS vs Non ABS wheels
Is there a difference?
Old May 7, 2023 | 02:16 PM
NorthWestern's Avatar
NorthWestern
It should just be the bearings that are used on most of the later model wheels. There is an ABS bearing with a tone ring that has to be used.
I could be wrong, but that is how it worked when I bought custom wheels for my FXDLS, HogPro wanted to know if I wanted ABS bearings, or not.
Old May 16, 2023 | 11:18 PM
NODYNA's Avatar
NODYNA
No difference in the rims. ABS is in the bearing on the left side. Factory HD ABS bearing usually have a pale green retaining collar.
Old Jun 30, 2023 | 03:32 PM
Gunnysgt's Avatar
Gunnysgt
Stock ABS combo is a 9252A bearing for the ABS and a 9276B bearing for non ABS side. The ABS bearing will be red on one side and green/gray colored on the side you see.
mikeo33y
Mar 10, 2023 05:06 PM
dgoodbmw
Jul 26, 2017 10:10 AM
smyffa
Nov 16, 2013 08:51 AM
BJFLHT
Aug 10, 2012 10:46 AM
keepertx
Apr 10, 2010 10:30 PM
