On mag wheels we use dyna beads. What's the date code on your C3 tire ? There were problems with older 19" front tires. I have a C3 on my bagger with dyna beads and it rides fine.
Took the wheel back to the shop. The place is a two man operation, the owner who sits behind a desk and the tech who does all the work.
Here is where it gets funny. I walk in with the wheel/tire. I could tell the tech was pissed off already. I hand him the tire and he starts in I dont give a F what anyone says - every tire needs weights, blah blah so I look at him and say - you would ride along with four and a half ounces on your front wheel? youd be ok with that? Really? You dont want to do this, give me back my fing wheel and Ill take it somewhere that gives a ****. He quieted down, pulled the core, deflated and broke the bead. Put it up on the clamps and said what do you want me to do - I told him to rotate the tire 180 and check it. (I already stripped off the quarter pounder worth of weights). He did, reinflated it and put it on the balancer. Spun it and loe and behold, 1.75 oz opposite the ounce and a quarter steel stem and Fobo TPMS cap. Nice. A crap load better than 4.5oz.
I just looked at the tech and said, well, how about that - the boss then came over and said Sorry.
Guess where Ill never go again
Just curious... Where was the orientation of the yellow dot on the tire when they first mounted it and where did it end up after they rotated it 180*?
Until this I bought my current 2019 FLHTP, my two 1989 and my 2002 ElectraGlides I balanced the rim without the tire. I would recheck when I'd replace the tires, but I never needed any additional weights with the Metzeler 880 or 888 tires when I put the dot on the valve stem.
For the first 40 years of street riding I changed my own tires
Had neither the equipment nor the inclination to balance a wheel /tire
I suspect many of us old guys did the same.
Not entirely true. My 120/70-21 Commander 3 has a red dot on it purchased in August.
Edit: Not sure what the red dot is used for though. They mounted it by valve stem.
Red dot is supposed to be the high or low spot on the tire, where the belts overlap. Yellow is supposed to be the lightest spot on the tire. Maybe they are only applied if such conditions exist. Which doesnt explain why then my issue was resolved by rotating the rubber 180 when no dots exist.
who knows.
nevertheless, its resolved. But Ill sure well continue to get advice.
I went through this same thing 2 years ago with a BRAND NEW wheel from H-D. Had the tire installed, put it on the bike, rode fine.... Until I hit about 68 mph ! WTF?! I had balance beads installed. Took the wheel back to the shop and long story short, ended up rotating the tire 2 or 3 times and it only moved the weight issue or made it worse. Took the tire off the rim and spun it on the balancer. The rim bare, was almost 4 oz. out ! GREAT. So I had to go with conventional weights. Now there's a good look. Sure made me feel good about spending all that $$ on a new CVO wheel. It does run nice and smooth, so I don't really think about it. After all, it's not a show bike. I just bought the matching rear last week. Will be checking the balance before tire install. If it's out more than an oz., I will add some Devcon to the light side and move on.
Anyone looking so close to someone else's bike is probably up to no good anyway.
I went to dyna beads…and never looked back. Smooth as silk ruding. One of the advantages is that the tires never loose balance from west. And no, they don’t sound like a “Hula Hoop”.
