Wheel compatibility question
Old May 1, 2026 | 08:04 PM
Usafexplorer's Avatar
Usafexplorer
Default Wheel compatibility question
Anyone know if the factory wheels off a 2015 Touring HD will fit a 2012 Touring model? I don't see a discernible difference but I'm not completely sure.
Old May 1, 2026 | 08:15 PM
Buelligan666's Avatar
Buelligan666
I put 2022 FLTRXSE wheels on my 2012 FLTRXSE. Bolted right on. Had to raise the front fender going to a 21" up front.
Old May 1, 2026 | 08:36 PM
Usafexplorer
Thanks that helps. The rims are actually the same size, 17" on the front the 16" on the rear. Everything I've read so far says the axles are the same size as well. Can't imagine HD changed a whole bunch between '12 and '15 but I'm new to these bikes so I don't want to make any assumptions.
Old May 4, 2026 | 07:14 AM
Architect's Avatar
Architect
Go to any Harley accessory book and look up wheels for your bike. It will give you a range of years that they will fit, it both bikes are in that range, you are all good. Could also check part #'s on the HD website Parts Finder, good luck.
Old May 4, 2026 | 08:41 AM
eighteight's Avatar
eighteight
Originally Posted by Usafexplorer
r. Everything I've read so far says the axles are the same size as well. .
^ Correct, proven by sharing the same bearing #9276B
ultracharlie
Wheels/Tires
May 10, 2025 06:53 AM
Puttnutt24
Nov 28, 2023 04:42 PM
cweiss
Aug 10, 2012 09:53 AM
gaslog4
Jun 11, 2012 07:09 PM
suey 1958
Dec 13, 2011 07:49 PM
