When to Replace Brake Fluid?
Old Feb 11, 2009 | 11:48 PM
jungleman's Avatar
jungleman
I got in the habit with my autos that when I change oil or every other time I take a turkey baster and suck the brake fluid out of the master cylinder and replace with new. It is hard to get a turkey baster in some of the resoviors but you can use other smaller things, hyperdermic needles etc.
Old Feb 12, 2009 | 09:22 AM
sniper77's Avatar
sniper77
Originally Posted by Dalton
Whew, I thought I was the only one that didn't change brake fluid.
Ron, you are right on the money. Brake fluid does not deteriorate unless contaminated. DOT5 does not absorb moisture. I am an old auto mechanic, hotrodder and bike builder and in all my years I have never just changed brake fluid as a maintenance item.
An for the guy that said new fluid made the brakes feel better, you cannot compress a fluid, no matter what it is so you must have had air in the system that you bled out thus making the lever stiffer. And for the recommendatin at every 10k miles - hell, I would be doing this twice a year !
I guess you never change brake pads either?
Brake fluid most certainly does degrade.
I suppose you think fork oil doesn't need to be replaced either?
All I can say from my personal experience is at least when the brake pads have to be replaced it just makes since to flush the old, black, worn out oil while you have the system open.
Old Feb 12, 2009 | 03:39 PM
rbabos's Avatar
rbabos
Then by all means knock yourself out and change it. As for the other comments, get real.
Ron
Old Feb 12, 2009 | 04:09 PM
ffdharley3's Avatar
ffdharley3
An for the guy that said new fluid made the brakes feel better, you cannot compress a fluid, no matter what it is so you must have had air in the system that you bled out !
Ya know its like new sneakers, they make you run faster.
Old Feb 12, 2009 | 04:19 PM
sniper77's Avatar
sniper77
Ron
Hey! Aren't you supposed to be busy cutting shock springs for custom lowering kits??????
Old Feb 12, 2009 | 05:12 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by Black Bart
Where, pray tell, may find some speed bleeders? And, what will they look like?
Bart
http://www.speedbleeder.com/
rbabos's Avatar
rbabos
Can't decide where to cut, top , bottom, or maybe the middle.
Ron
Old Feb 12, 2009 | 05:16 PM
KBFXDLI's Avatar
KBFXDLI
How many actually change brake fluid in their cars? Havn't done a single car in my 40 years of driving. Unless major work is done, it aint needed. It's a none compressable fluid and don't change. It can't absorb moisture in a close system unless you drive around with the cap off as it's not vented to atmosphere. There is nothing special with a Harley that needs periodic fluid changes.
Ron
Ron: Go bleed your front caliper and you will see how much deterioration the brake fluid goes through. Water finds its way in and that does compress and degenerates your brake performance. My bike takes Dot4 which degrades 2x faster than Dot5. Same with the cars. They get flushed with every re-line.
Old Feb 12, 2009 | 05:28 PM
Wecroft's Avatar
Wecroft
Water compresses? When did it start doing that? Must be a new law of physics that I missed the note about.
Old Feb 12, 2009 | 06:57 PM
rbabos's Avatar
rbabos
Technically it does, but about the same as brake fluid. Forgot the number but it is freakishly, rediculously small in amount and meaninless.
Ron
