metzeler tires
Old Jul 2, 2009 | 08:13 PM
t_risner10@yahoo.com's Avatar
Stage III
Default metzeler tires
I went to metzeler 880 marathon tires on my Ultra Classic. The rear tire 140/90 is wearing flat in the middle instead of all the way across the tread and is worn out at 7000 miles. Is this an air pressure issue? I've never had this problem with Dunlops. The Dunlops wear fairly even all the way across and last 9000 - 10000 miles. Any help would be appreciated.
Old Jul 2, 2009 | 08:15 PM
Notgrownup's Avatar
Notgrownup
Metzellers wear out faster. softer coumpound...7k miles///about right
Old Jul 3, 2009 | 04:53 AM
elPrez's Avatar
elPrez
I'd get about 8,500 on my Road King Classic before you'd see cords showing through. Just replaced the rear on the Ultra and was surprised at how much was left after a bit over 10,000 ( probably 2,000 left but heading to Deals Gap next week )
I did switch to a Dunlop E3 based on the reviews on this forum so I'm looking forward to see how much I get with it.
Old Jul 3, 2009 | 01:43 PM
kurtlange's Avatar
kurtlange
not really. i've been getting 10-12000 on an 04 eglide.
check your air pressure. metzlers run 48-50 in the rear.
Old Jul 3, 2009 | 08:34 PM
Notgrownup's Avatar
Notgrownup
Never got more than 8k on rear of my eglide...You must be a real easy rider is all i can say...i need to take lessons from you....
Old Jul 3, 2009 | 09:59 PM
Moonrider's Avatar
Moonrider
I also got about 8k on my Me880s. Still much better tire than the dunlops.
Old Jul 3, 2009 | 10:40 PM
Not E'nuff Harley's Avatar
Not E'nuff Harley
I'm lucky to get 4000 out of a rear tire. Can't figured out why, either!
Old Jul 7, 2009 | 05:29 PM
RE AND CHERYL's Avatar
RE AND CHERYL
What pressures should I run front and rear on a Ultra running Metzlers. I'm running about 40psi front and 42psi rear. Is that too low??
Sorry for the hijack
Re'
Old Jul 7, 2009 | 05:36 PM
turn8a's Avatar
turn8a
Re'
you have to check out the metzler web site for my size 880 they recommend
150/80/16 40-42 psi and the front 100/90/19 38 psi
Old Jul 17, 2009 | 08:53 AM
ezryder1962's Avatar
ezryder1962
metzelers with numaric sizes require more air because thay have two belts and not three metzelers with new alpha size have three belts need less air. read the side wall of tire it will tell u max air presure if you have old style tire you cant run 38lbs
