Warm tire pressure
Old Aug 14, 2009 | 06:49 PM
big_e78's Avatar
big_e78
Default Warm tire pressure
When I go to get on the bike, all I think about is wanting to ride. When I pull into the garage, all I think about is getting inside. Often the only time I think about my tire pressure is while I'm riding, unless I'm tinkering in the garage. What should the pressure be while tires are hot (38 cold) ? How long till "cool"?
Old Aug 14, 2009 | 07:37 PM
tibadoe's Avatar
tibadoe
Best to check them in the morning before you head out. They cool overnight and checking then will give accurate results.
Old Aug 14, 2009 | 08:23 PM
rbabos's Avatar
rbabos
Check cold and it is what it is when you are riding. It will be constantly changing hot so there's no exact figure to go with.
Ron
Old Aug 15, 2009 | 06:32 AM
grbrown's Avatar
grbrown
Also bear in mind that changes in daytime temperature may affect pressures. If it is cold out pressures are likely to be lower than if you last checked them on a hot day. If you don't ride very often you should check before your ride. How about while having that last coffee before you set off?!
Old Aug 15, 2009 | 11:13 PM
genedjr's Avatar
genedjr
Cold tire pressure is the only measurement that I have found that is standardized. BUT - if you are running 30lbs hot - fit it the F" up. Heating only increases pressure.
...gene
Jack Dawkins
2014-2024 Touring Models
Jan 19, 2018 03:10 PM
GregLeo
Nov 26, 2016 08:53 AM
JimGnitecki
Sep 6, 2015 12:47 PM
SWThomas
Mar 13, 2015 04:22 PM
tuckertaft
Aug 16, 2010 03:48 PM
