Rotor Question
Old Sep 24, 2009 | 07:11 PM
mmitchell's Avatar
mmitchell
Default Rotor Question
Guys, I have a warped rear rotor on an '06 ultra. I replaced my front rotors with floating rotors and have the take offs. Does anyone know if the fronts will fit on the rear?
Thanks,
Mike
Old Sep 25, 2009 | 07:35 AM
1flhtk4me's Avatar
1flhtk4me
Do they look the same?
Old Sep 25, 2009 | 11:37 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Front rotor bolts are 5/16" and the rear are 3/8" so you won't be able to simply bolt a front rotor onto the rear wheel. You can bore out the bolt holes on a front rotor to 3/8" and then use it on the rear.
Old Sep 25, 2009 | 04:50 PM
FastHarley's Avatar
FastHarley
Former Sponsor
And while you are at it you need to machine a collar to fill the gap as your front rotor registers are 2.224" and your rear is 2.0". If you wish to run the rear rotor without a collar than all of the rotational load will be placed on the bolts and they will twist just as crooked as the banking world on wall street. Once some of the bolts finally shear than the rotor will **** than the rest of the story is unknown. $45 gets you a new one on e-Bay.
Old Oct 1, 2009 | 04:52 AM
mmitchell's Avatar
mmitchell
I think I'll do a new rotor, Thanks all.
ronbeejer
Jan 16, 2019 08:28 AM
bklynbob
Mar 7, 2016 08:39 AM
Tarponrod
Sep 14, 2013 12:00 PM
olongapo1
Nov 18, 2012 02:25 AM
Figstr
Nov 3, 2009 07:59 PM
