Famous high speed wobble
Old Jan 19, 2012 | 06:11 PM
02Nighttrain's Avatar
02Nighttrain
6th Gear
Originally Posted by 02Nighttrain
Lower tire pressure? HD just told me to run it at 30 psi front & 40 psi rear. I will try a lower tire pressure. I also have the dunlop 21" stock tire from hd on it. My buddy has apes on his 1200 sporter and hasn't experieced the wobble yet. Do you think its the apes?
Found out the problem. The rear wheel was out of true. Hd dealer didn't true up the wheel when they installed new tires. Never going there again for service!!
Old Jan 29, 2012 | 04:58 PM
dbrown5's Avatar
dbrown5
just saw this thread.... my bike does the same thing at about 70 but the thing is that it only does it bad on the highway... a bike shop said it was because i had a met back tire and dunlop front so i changes to new met front... still does it but not as bad... and i put a new spoke rear rim on bout the same time i noticed it... where did you take it to? local shop or hd? and if you dont mind how much did it run you?
Apehangn
Aug 18, 2014 11:35 AM
Quadancer
The Dark Side
16
Jul 6, 2013 08:15 AM
PTAG
Aug 25, 2012 10:24 AM
TAWoody
Jul 21, 2010 08:47 PM
Mi3ninos
13
Jul 9, 2010 06:43 PM
