Front brake problem on '07 RK
Old Aug 2, 2010 | 08:43 AM
HogRock Vet's Avatar
HogRock Vet
5th Gear
Default Front brake problem on '07 RK
I hit a raccoon last night. Actually it hit me. lol
The only damage that it seems to have caused is this.......
I have to squeeze the brakes 2 or 3 times, before they work.
I can't really afford to take it to a mechanic right now, so I am hoping this is something I can fix myself?
Any advice would be greatly appreciated!!!!
Old Aug 2, 2010 | 08:48 AM
HogRock Vet
5th Gear
One more thing.
I have looked closely, all around the caliper and lines, and can't see any damage, or leaking fluid.
I think the coon hit right on the disk. In fact, if I just coast slowly, I can hear a very slight intermittent rubbing. So, it must have just barely bent the disk. Not enough that I can see any warp in it though.
Old Aug 11, 2010 | 07:05 AM
HogRock Vet
5th Gear
No advice from anyone?
Old Aug 15, 2010 | 08:54 PM
challutz's Avatar
challutz
try bleeding them, and make sure your fluid level is good
Old Aug 16, 2010 | 10:11 AM
b0fh's Avatar
b0fh
if your disk is warped, it wil push the pads farther out and some pumping will be needed. I un-warped my rear disk once (had to change the tire in the middle of nowhere and the guy warped the rotor) and it is not difficult, just removed the wheel and used a ruler to check and a piece of metal rod to 'adjust'
cheers
Daytona Glider
Feb 3, 2023 07:43 AM
msafrit
Apr 25, 2018 03:36 AM
Cull22420
Apr 16, 2015 09:02 PM
RedBen
Aug 13, 2010 09:00 AM
sledhead140
May 10, 2009 03:36 PM
