Couple quick tire change questions
Old Aug 8, 2011 | 09:47 AM
Little Mike's Avatar
Little Mike
Default Couple quick tire change questions
The first just to confirm, the rear axle nuts require a 36mm socket, yes? If I can't find 36mm is there too much play in a 1 7/16" socket? The other is where is the manufacturing date code printed on the tire? I've read that some folks have gotten old ones from DK. I ordered mine from Motosport.com on the recommendation of a friend who has gotten 3 sets from them with no problems but I want check just to be sure. Thanks in advance for any insight you may be able to share.
Old Aug 8, 2011 | 10:06 AM
Little Mike
Think I figured out the manufacture date part. After the DOT code there is an oval with a 4 digit number imprinted inside it. I believe that is the week and year. Is that right? If so then I think their inventory roll over is pretty good. The rear was made in Dec. of 2010 and the front in April of 2011. The rear isn't too old is it?
Old Aug 8, 2011 | 10:11 AM
Sefferdog's Avatar
Sefferdog
36MM is correct. A 1 7/16 would be a little loose, but may work.
Here is a pic on tire dates. The red highlighted is week/year:
Old Aug 8, 2011 | 10:22 AM
Little Mike
Thanks Sefferdog. I think I'm good then the last four on the tires are 4610 on the rear and 1711 on the front.
Old Aug 8, 2011 | 05:14 PM
grbrown's Avatar
grbrown
I use a 38mm adjustable wrench, bought on ebay. There are several similar compact ones (8/9" long) that just fit the bill and don't break the bank.
Frozen Excursion
Jul 29, 2018 11:10 PM
GroovusMagnus
2014-2024 Touring Models
30
Mar 19, 2018 01:40 PM
Dan1127
Aug 3, 2015 11:44 AM
Briboysr
May 17, 2014 08:39 AM
ramu3527
Apr 9, 2013 02:20 PM
