Single disk on old bagger
Old Aug 15, 2011 | 08:28 PM
Chopperguy99's Avatar
Chopperguy99
Default Single disk on old bagger
Hey guys and gals. I have a 1988 FLHTC. She is gonna get a 21" front wheel and matching rotor. It has the dual, single piston brakes. I was thinking of running a single disk setup and cut off the brake tabs before powder coating the legs. Would a 9/16" bore master cylinder and a quality 4 or 6 piston caliper provide better, or at least as good stopping power?
Old Aug 17, 2011 | 06:58 AM
grbrown's Avatar
grbrown
You need to change to the smaller diameter master cylinder. I have the stock twin caliper set-up on my 1990 bike, but with 6-pot calipers. If you fit a single 6-pot you will still need a single caliper master cylinder. However check that with your chosen brand supplier!
Old Aug 19, 2011 | 11:58 AM
Chopperguy99
Thanks! I think I have decided to use the HHI 6 piston. I will find out the recommended master cylinder bore. Thanks! The stock front brakes really suck!!
Roadkill73
Jan 19, 2014 10:45 PM
hajones98
Oct 2, 2012 02:56 PM
Jswerve
Sep 18, 2012 10:46 AM
baggerdoug
Nov 6, 2011 02:56 PM
