Street glide wheel
Old Jun 19, 2012 | 10:08 PM
plumberoon's Avatar
plumberoon
Stage IV
Default Street glide wheel
Hey guys i'm fixing a wrecked 08 SG and i was wondering if i can put a 2011-2012 18'' SG wheel on mine? It has a 16'' now.Thanks
Old Jun 20, 2012 | 03:38 PM
grbrown's Avatar
grbrown
I suggest you go over to the Touring forum and take a look. IIRC the later bikes use different diameter rotors and calipers. Also the rear is much wider and not easily fitted to earlier bikes.
Old Jul 19, 2012 | 01:17 AM
dvious141's Avatar
dvious141
You can upgrade to the 18 inch wheel, I'm about to tackle this task in a couple of weeks. You need to get a 2010-2012 axle (25mm axle) or have your original 1 inch axle machined to equal 25mm. Swap over your rotors from the 16 inch and change out the bearings if the wheel is off of an ABS equipped SG. I think I'm forgetting something so I hope someone who has done this will chime in.
Old Jul 21, 2012 | 12:01 PM
Ridindirty's Avatar
Ridindirty
6th Gear
As far as the front wheel goes. It would be a direct swap. Rotors and bearing size are the same. Along with the axle The rear is a different story. This would not fit as HD changed a few things (larger wheel).... as Dvious141 said. Just make sure you see if it has abs or not!
D Sandman
Jan 26, 2018 07:44 PM
GeorgiaDawgs
Jun 5, 2014 11:18 AM
NCBondsman
May 13, 2014 09:32 AM
Abnmarine
May 20, 2008 11:12 PM
72 chopper
Ironhead
May 5, 2008 09:24 AM
