what size?
Old Jul 29, 2012 | 09:04 PM
god61021's Avatar
god61021
Default what size?
Just changed my brake pads today on my 04 heritage classic, first time on a bike but it was way easier than a car. anyway I could not find a socket or wrench to fit the valve or whatever the hell you call it (the part you loosen to bleed the brakes) anyway Im thinking I needed a 9.5mm wrench. Is this correct?
I was able to get the job done without needing to bleed em' but id like to find the right wrench for next time.
Old Aug 1, 2012 | 01:33 AM
god61021's Avatar
god61021
53 views an noone can mention they dont make a 9.5mm wrench? lol
Old Aug 1, 2012 | 07:36 AM
Ridewva's Avatar
Ridewva
3/8" is what I use on my 04 Dyna. The bolt heads seem pretty fragile so I use a 6 point box wrench to crack it loose.
Old Aug 1, 2012 | 09:39 AM
god61021's Avatar
god61021
yeah 3/8 fit fairly well but began stripping it if I put too much pressure so thats why I just assumed it would be metric like some of the other bolts on the caliper. then when 9mm was too small and 10mm was too big I assumed it was 9.5 afterall I was able to find a 5.5mm and a 7.5mm in my toolbox so it must be 9.5mm right. then I went to work and tried to get the maintenence guys to order me one out of their catalogs. they loved it. they also offered to order me things like bolt stretchers, left handed pipe wrenches or anything I wanted out of the basement. bunch o' dicks. lol
Old Aug 2, 2012 | 10:53 AM
grbrown's Avatar
grbrown
There is no 9,5mm spanner. I think you'll find those two you have are the only ones that are not whole mm.
nweb992000
18
May 9, 2017 08:28 AM
beanoboy
Feb 11, 2017 02:17 PM
Pete6114
Wheels/Tires
Sep 16, 2012 02:57 PM
TampaJim
Apr 5, 2012 05:37 PM
79lowrider
Oct 13, 2009 04:15 PM
