Wheel Change
Old Oct 26, 2012 | 08:48 AM
Philouk's Avatar
Philouk
5th Gear
Question Wheel Change
Guys n Girls
I am trying to get an 010 Fatboy front wheel into my 06 Softail std!
I have made a rotor spacer and that puts it all in line..
My question is ....Will the wheel installation kit for the STD fit the Fatboy wheel, bearing in mind that the Fatboy wheel has 15mm x 25 x 52 ABS bearings and the Std 's are
3/4"(19.05mm) x 21 x 52mm
Would I also be able to use existing spacers etc.
Many thanks Philo
Old Oct 26, 2012 | 10:22 AM
No Name Motorcycle Shop's Avatar
Harley changed the hub in 2007. The bearings/spacers in the wheel install kit for your 06 will not be correct w/out modification due to spacing differences. We have tried to put a 2001 front laced wheel on a 2007 bike, from Duece to a Night Train, and could not get the spacing correct using stock components. We do not like to modify/machine spacers and such unless we absolutely have to do so.
I hope this helps
Old Oct 26, 2012 | 02:16 PM
Philouk's Avatar
Philouk
5th Gear
many thanks.....best I get the lathe spinning
Trollboy
Wheels/Tires
May 4, 2018 11:05 AM
Beemervet
Wheels/Tires
Jan 18, 2018 05:33 AM
harley7316
EVO
Jul 23, 2011 11:36 AM
CamFX
Dec 23, 2008 11:14 AM
KRUSE
Apr 14, 2008 08:30 PM
