Tire decision
Old Aug 20, 2013 | 03:34 PM
homiegfunk53's Avatar
homiegfunk53
Default Tire decision
I have a 1992 Heritage Classic with a 130-90-r16 in the rear on the stock 16" spoked wheel. Its all up in the air as what I am going to do, but I have a fat boy rear fender I may customize and install on my bike. Now, in my opinion, everytime I see a fat boy go by, that back tire seems wider. Is that because of the rim or the fender? Long story short, my bike is belt driven, with that stock rim, what is the widest tire I can fit? Thanks
Old Aug 21, 2013 | 12:32 PM
grbrown's Avatar
grbrown
Without major surgery, probably an MU or 140-85-16. You're limited by fender width and belt clearance from the tyre.
Old Aug 21, 2013 | 01:37 PM
homiegfunk53
If I used a fat boy rear rim, with the fat boy rear fender, on my 92 heritage classic would I be able to fit a wider tire? Beside changing to a wider swingarm, how can I get a wider tire on?
Old Aug 21, 2013 | 01:44 PM
grbrown's Avatar
grbrown
I suspect you will find both fenders are similar in width. The main limitation you have is your wide belt and clearance with the tyre. All rear wheels around the time your bike was made are the same width, 3". The widest tyre that will fit that is 150, however you don't have enough clearance with your belt.
You can get a 150 in using a narrower belt, either 1" or 1 1/8", which involves removing the primary, to get the narrow belt on, and replacing the wide pulley for a narrow one to match the new belt. But you should check that to make sure the parts will fit your bike, especially the new rear pulley.
Old Aug 22, 2013 | 02:10 PM
homiegfunk53
Ok thank you. I saw that have 1" rear pulley spacers, but am yet to discover what to do up in front. Any thoughts?
wesman16
Wheels/Tires
Apr 28, 2018 09:59 PM
M16pilot
2014-2024 Touring Models
Apr 17, 2017 01:20 PM
homiegfunk53
Aug 23, 2013 04:27 PM
frodin1
Jul 12, 2013 11:16 AM
amtrains
Wheels/Tires
Nov 24, 2010 12:48 AM
