Well learned my lesson with shinko tires
No it got to that point last Sunday in the middle of a 200 mile ride. I just put it on May of this year and it only has a little over 2,000 miles, no burn outs or lock-ups I swear! I'm an old man and don't abuse my bike with burnouts! However, according to Shinko, I did run it at too low a pressure at the factory spec of 32psi. They said it should be run at 49 to 44 psi. I honestly did not know that, but I always check it before each ride and do have a good gauge, I am a professional auto mechanic by trade. Good news, Shinko are top rate and are sending me a new tire. Here is the message from the factory:
Our tires are destined to be run at what the sidewall of the tire says and not the owners manual. The owners manual specs are for the OE (original equipment) tire that came on it from the factory. That specific size and model (130/90-16 777 series) is actually supposed to have 49psi max and no more than 4-5lbs below that for rider comfort. Running these tires at 32 psi will literally destroy the tire because they are building up to much heat.
We'll see how long the next one lasts, but I will for sure run it at 49psi and not let it get below 44 psi. I really do check the pressure every time I go for a ride.
I use the 130 also. Just never did get the obese tire fad. In corners and curves they require earlier line selection and are slow switching over to the other side. 130s hit the curves so much better. I run mine on a sportster though so I run them on the lower side of the spec just fine. What are you running the front 777 at? What size front you run? I like the 90/90 21" on mine best and of any tire in any size, the 21" 777 is the straightest tracking smoothest running front I ever ran. They could charge double the price and it would still be cheaper than the cool kid big brand name tires. Wet road performance is also unmatched.
I am happy they took care of you. Your ride should be alot better too when you get the right psi in them. I notice a 2psi drop in mine when I hit the curves and bumps hard so watch that psi!
DirtyDave1116 (05-20-2016)
Its don't bother me either what it says but replacing a tire every 3000 to 4000 miles i don't think i want to do that. I also do my on work but i just can't see it. Like i said i got 10,000 out of my dunlop 402 which i will not buy another one of them either (cupped real bad). I think i'm gonna try dunlop elite 3 i've seen and heard good things about the tire.
Your tires
I bought four brand new Yokohama for my 2003 Audi TT Quattro. I hit a pothole, and on the passenger side two tires blew out! Sidewall blowout, and the people that sold me the tires told me there was nothing they could do. I'm 50yrs old,not some inexperienced person with stuff like this, and I just knew the tires were defective because brand new tires at $190 a piece that will blow out on the first pothole means that Yokohama is making and selling defective product, AND from what I understand, Yokohama has something to do with this brand of tire. I will pay more money for the Dunlop and I will feel safe while I am riding them as my dunlop's are now dry rot and need to be replaced after 25,000 miles on my 2001 Harley Davidson Sportster that only has 25,000 miles on it so go figure on how old those tires are and how long they last for me I will pay that for the expensive tire so at least I feel safe while I am riding
Received 14,658 Likes
balingwire
Wheels/Tires
11
01-10-2024 03:38 PM
