28 knucles
Old Jan 18, 2014 | 12:34 PM
kitt90's Avatar
kitt90
Default 28 knucles
I have a 2007 rk with 16 inch wire spokes and www s I was wondering if I could run a set of 28 knuckles off of a 2009 rk will the wider 17s fit on my bike with out changing the swing arm and changing my front fender and the front axel bearings
Old Jan 20, 2014 | 08:55 AM
grbrown's Avatar
grbrown
Talking
No, the rear won't fit, without a lot of surgery! The new tyre is actually wider than your current fender and the hub won't fit your swingarm. A member has made the swap, but he cut and welded his stock swingarm, also cut and welded his fender and did a real custom shop job to make it all work.
Another member has cut off the rear sub-frame and welded on an 09-later sub-frame. If you have the skills and equipment it can be done, but it is not for mere mortals!
Old Jan 22, 2014 | 12:01 PM
kitt90's Avatar
kitt90
thanks to bad I found a great deal on the 28 knuckels
iflybyu
Jan 31, 2015 11:32 AM
kirby666
Nov 2, 2013 02:11 PM
patcham48
Feb 20, 2013 02:41 PM
LoBoT
Jul 9, 2012 02:49 PM
Kickstand03303
Jun 3, 2012 04:33 PM
