need help wiring tail light
Just so you know, the wires that run to the center tail lamp on the Street Bob (Donky Dick version, 2010 and newer I believe) only has the three wires mentioned. The Red/Yellow, Orange/White and Black and that is why I told you this way, there is no Blue wire running to it, it only goes to the two turn sigs.
Hope that helps.
Personally why use the O/W when the Blue is the actual running light? He has an 04, not a newer bike.
Its only a personal reference but most of it is close to the stock setup in the wiring diagram in the book. (06'-newer)
In order to help you solve your problem I would like to know how many bulbs this model a light has and if there are single or dual filament lamps.
Could you post some images?
In general I can say:
Types of bulbs used in taillights are:
- Dual filament for brake/tail light 20W/5W
- Single filament 20W as brake light
- Single filament 5W as tail light
- Festoon bulb 3-5W as a tag light.
Color codes to use on your Dyna 2004:
Blue for running/tail light and tag light
Red/yellow as brake light
Black to ground
8541hog is right: Orange/white has power when ignition key is turned into Acc and Ign position. This wire is used on HDI models to feed the taillight when the bike is parked at night.
Here's in image I posted some time ago on how to wire a double filament taillight:
No Brake
Brake
Back of housing
It is well worth the $30 bucks to add the LED conversion and its plug and play, no extra wires to run or anything.
