Trottle Position Sensor Help!!
Old 07-30-2015, 12:02 PM
JCF's Avatar
JCF
JCF is offline
Default Trottle Position Sensor Help!!
Long story short...just changed my bars, engine light comes on after 20 minutes. I've done lots of reading and its probably the TPS. My question is....will it be safe to ride in Sturgis? I leave in 2 days and don't want to get stuck. The engine light comes on but, it has not gone into limp mode. Anybody ridden with this problem? Just need to make it through Sturgis. Thanks Guys and Gals!!!!
Old 07-30-2015, 01:14 PM
J929626's Avatar
J929626
J929626 is offline
What code(s) are you getting?
Old 07-30-2015, 03:46 PM
JCF's Avatar
JCF
JCF is offline
Old 07-30-2015, 07:27 PM
J929626's Avatar
J929626
J929626 is offline
2135 is a TPS correlation error, probably related to the replacement of your bars and the dreaded "green plug".
1511 throttle actuator control power management failure of throttle control actuator and is normally related to a bad connection on the plug behind your A/C, that you can disconnect, clean and reconnect.
When I changed my bars I did get error codes, went into limp mode and lost throttle control. I would not want to go on a long ride with that hanging over my head.
chief1600
08-25-2021 07:04 PM
geopac
02-21-2016 12:39 AM
09rkpolice
02-09-2013 08:03 PM
Freeway
02-09-2012 10:57 PM
BigDaddyMike
06-15-2011 11:49 AM
Quick Reply: Trottle Position Sensor Help!!
