Harley Paint Clear coat or not
Old 08-27-2006, 03:32 AM
05 Spring Class's Avatar
05 Spring Class
05 Spring Class is offline
Default Harley Paint Clear coat or not
Ok stupid question,, But what type of paint does harley use?? is it a clear coat or a base paint??
Have the sunglow Lava and viv Black looking at waxs want to make sure I get the right one.
Old 08-30-2006, 07:54 PM
SoCalFXSTI's Avatar
SoCalFXSTI
SoCalFXSTI is offline
Default RE: Harley Paint Clear coat or not
05,
The clear is over the color.
Old 08-31-2006, 01:13 AM
nikonf8's Avatar
nikonf8
nikonf8 is offline
I believe Harley paint is clear coated
Old 08-31-2006, 10:38 PM
GPDM's Avatar
GPDM
GPDM is offline
6th Gear
Harley does use clearcoat, but speaking from past experience be careful with it because it scratches easily.
Old 08-31-2006, 10:52 PM
Scout's Avatar
Scout
Scout is offline
It's a five part system made by PPG. Fill, base, colour(s), stripes, clear (not including activators and solvents). The touch up bottles that the dealer sells are a one part (meaning no kicking over with activator or solvents) crappy colour match.
You can buy the exact colours from a PPG Premium dealer, but the prices are crazy. Any good paint dealer will be able to match the colour using a digital scan, and then you do not have to pay the HD upgrade in pricing.
Old 08-31-2006, 10:58 PM
Scout's Avatar
Scout
Scout is offline
ORIGINAL: GPDM
No, that is exactly wrong. The colour coat is almost flat (less than 45 degrees gloss) and is able to be repaired or sanded before clear application easily. The clear coat has no pigments, and therefore flows much more evenly, and gives a smoother, higher gloss finish than a enamel topcoat. Clears have huge amounts of hardeners and U.V. protectant in them, and once they are cured, perform much better than enamels. The reason most cheap painters use enamels is that clear means one more application, meaning time and money, so these myths are always spread around.
Old 08-31-2006, 11:03 PM
Scout's Avatar
Scout
Scout is offline
Last post on this one. I have some of the mix formula's. if you guys want them, PM me the year, bike, and colour, and if I have it, I will send you the formula.
Yeah, I'm a painter. Automated flat line for furniture components and signage, but do play around with cars and bikes in my spare time.
Old 08-31-2006, 11:29 PM
Coaster's Avatar
Coaster
Coaster is offline
Good info Scout! Thanks.
Uncle Bull
Powdercoat & Paint
02-06-2014 04:59 PM
dspencer
08-24-2011 07:31 AM
05 Spring Class
Powdercoat & Paint
01-21-2011 03:36 PM
cuda67bnl
10-29-2009 02:27 AM
JohnAE
05-14-2009 08:42 AM
Quick Reply: Harley Paint Clear coat or not
