General Handle Bar Question
I am looking to replace my handle bars and hand controls. I would like to have all the cables run internally. I dont know if its possible but I want everything internal (Clutch cable, brake cables, throttle).
Question:
Is what I want Possible?
What do I need to look out for when making a purchase to ensure Im ordering equiptment that matches my goal? Do the handle bar and control product literature need to contain certain magic words that I need to be aware of. I hear things like internal wiring enabled and predrilled for internal wiring. Is there anything else?
Finally, Are there any dangers or pitfalls in having all the cables run internally?
Thanks everyone.
Question:
Thanks everyone.
I can tell you from personal experience that running the wiring internally is pretty simple and yes you do need bars that indicate pre-drilled for wiring. As far as clutch and throttle cables goes, I am not completely sure, but I do know that you can get a twist clutch. For installing all the wiring for a stock harley and cables through the bar, I think it would be difficult as it was a chore to get just the wiring through my bars. As you indicated in your post, I believe you would need to get new controls and rewire the bike as i do not think you would be able to have the controls on the bars with this type of set up.
There are some real nice options to do it, but having it all internal will double the cost of the bar swap. I think it was Joker Machine that had a real nice setup for them. I'll see if I can find a link.
ETA, it does not appear to be them, but I will find it.
Thanks for all the input. I love the look its really clean. I also like the idea of a twist clutch. How different is that.
So assuming, im going with bars that are pre drilled, is it as easy as finding controls are say they are for internal wiring?
Ill check out all the links you guys have provided. thanks!
I have an internal throttle (Streamline) on my bike with custom bars from BR's Custom Bars. You will need two holes on both sides of the bottom of the bars (for the clutch and throttle cables) and one hole in the center (for the control wires). I went from four external cables to two. I have 1.25 inch bars and I believe if you are going to do all internal wiring, brake line and internal throttle and clutch cables you will need 1.5 inch bars. Here are some more options to consider:
- Exile Custom Cycles (internal throttle and clutch)
- J&P Cycles (internal clutch)
- Kraus Motors (internal clutch,throttle and brake system) might take some getting used to.
- MotoXCycle (internal throttle)
- Streamline Designs (internal throttle)
- Viscious Cycle Works (internal clutch)
- Viscious Cycles (internal throttle)
