2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
2014 vs. 2015 ultra Limited
Old 01-27-2015, 09:13 AM
heritageblue2013's Avatar
heritageblue2013
heritageblue2013 is offline
Pretty much the same. Colors on the 15's are sucky
Old 01-27-2015, 09:17 AM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
Originally Posted by Gwaxley
Recently found out there is a diferance with the 15 ecm. The 14 will not advance the timing without sensing a load, maybe just for crusing I do not have all the details at this time, but there is a diferance. If you dyno/tune a 2014, the Harley dealer will need to flash the 2015 modification beforehand.
So what happens if you already have a tune on a 14, do you still get the 15 flash, re-tune, ?
Old 01-27-2015, 09:27 AM
Greg2012FLHTK's Avatar
Greg2012FLHTK
Greg2012FLHTK is offline
Here is a lnk to the thread I started that included info about the ECM update. Some people said there dealers better not do the update on there bike and wipe out the tune from when they paid to dyno tune there bikes. https://www.hdforums.com/forum/new-r...k-service.html
Edit. That thread is from when I first mentioned the update. Cant locate the thread that was only about the update.
2nd edit: Here is the link about the ECM update and all the comments: https://www.hdforums.com/forum/new-r...re-update.html
Old 01-27-2015, 09:54 AM
tpcowfish's Avatar
tpcowfish
Tnx Greg, but i'm still confused ?
Old 01-27-2015, 10:05 AM
Greg2012FLHTK
Your not the only one. If you read the thread in the 2nd edit. As of November some dealers were saying there was no update or the ECM can't be updated. Even some of the dealers were/are confused. Someone mentioned if you have a custom tune you could save it get the update then reload your custom tune. All I can tell you for sure is they updated my ECM that still had the stock tune.
Old 01-27-2015, 06:28 PM
YPD485's Avatar
YPD485
YPD485 is offline
Originally Posted by Markallamerican
Paint colors. I didnt know there was a gauge difference. I will have to look next time Im at the dealer
I believe the instrument gauge change is that the ABS warning icon has changed on the 15's. And of course the price went up a bit and some color changes.
Old 01-27-2015, 08:18 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
There is no reason you couldn't save your tune, flash the ECM, then reload the tune. The bitch would be, if you flash your ECM before you save the tune. At that point it would be lost.
The tune can be saved on a device like a Powervision, or on the dealer's hard drive using your SERT.
Old 01-27-2015, 09:08 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
OwnerOfHarriet is offline
I found no difference except the 14 was less expensive. What ever the extra depreciation might be on the 14 makes no difference to me since I will put lots of miles on it anyway and keep it many years --
Old 01-27-2015, 09:32 PM
Uncle Paul's Avatar
Uncle Paul
Uncle Paul is offline
Think the low will be very popular. Was just at a dealer where they had a standard Limited parked right next to a Low.
Felt like the low was 100 lbs lighter when straightening it up off the stand. Much stronger stance by getting feet not only flat on the ground, but also with some bend in the knees.
With the upgraded and lowered suspension on the Low, I believe it will not only be much more nimble around town, but still about as comfortable on the road.
Old 01-27-2015, 09:36 PM
Bikerscum's Avatar
Bikerscum
Bikerscum is offline
^^^ this ^^^
Quick Reply: 2014 vs. 2015 ultra Limited
