I'm not able to reset the Average MPG on the FP3. When I first installed the FP3, it had a bogus number of 1,400 MPG and by pressing the reset icon on the sensor data screen on my iPhone, it did reset it to 0 and began to read correctly. Now after I reconnected the FP3 to the bike after having it off for a while, it reads artificially high again (1,500) and it does nothing when I press reset. V&H said they will look into it. I did a reboot of my phone and iPad but no luck there either. Just wondering if anybody else is experiencing this.
I did reset it like you did on first install but I never removed the FP3 from the bike and I can still reset it. I am sure they will find a fix for you. Have you tried to delete the app and then download it again? I have had other app issues and that always seemed to fix them.
Unfortunately there was a bug within the last update of this feature. It has since been fixed but we are waiting on Apple's approval process for the application. There is no set timeline but typically within 1-2weeks.
Just came in from adding 1 firecracker into my map which cleared up any remaining decel pop. Wanted to see how rich I was running so I took the scoot for a ride and when I came back and looked at FP3 it showed 2134 MPG. Came on here to see if anyone else had this issue.
Hopefully Apple approves your update shortly, I really want to see if I'm running too rich with the firecracker on 1.
Other than that, bike runs like a raped ape. Completely different bike from stock, man these things are choked up from the factory.
This thread is almost a year old and Vance & Hines fixed the problem with a firmware update right after this thread got posted. Make sure your firmware is up to date.
